On the Edge-length Ratio of Outerplanar Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theoretical Computer Science Année : 2019
We show that any outerplanar graph admits a planar straight-line drawing such that the length ratio of the longest to the shortest edges is strictly less than 2. This result is tight in the sense that for any ε > 0 there are outerplanar graphs that cannot be drawn with an edge-length ratio smaller than 2 −ε. We also show that this ratio cannot be bounded if the embeddings of the outerplanar graphs are given.
Edge-length-ratio-TCS.pdf (953.1 Ko) Télécharger le fichier
Format : Figure, Image
hal-01886947 , version 1 (03-10-2018)
Sylvain Lazard, William Lenhart, Giuseppe Liotta. On the Edge-length Ratio of Outerplanar Graphs. Theoretical Computer Science, 2019, 770, pp.88--94. ⟨10.1016/j.tcs.2018.10.002⟩. ⟨hal-01886947⟩
211 Consultations
213 Téléchargements
