On Implicit Finite-Time and Fixed-Time ISS Lyapunov Functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
This article presents a theoretical framework to study finite-time and fixed-time input-to-state stability of non-linear systems using the implicit Lyapunov function formulation. This approach allows to determine stability, robustness and convergence type of a given system without relying in an explicit Lyapunov function.
CDC18_0753_Paco_A.pdf (544.41 Ko) Télécharger le fichier
hal-01888526 , version 1 (05-10-2018)
  • HAL Id : hal-01888526 , version 1
Francisco Lopez-Ramirez, Denis Efimov, Andrey Polyakov, Wilfrid Perruquetti. On Implicit Finite-Time and Fixed-Time ISS Lyapunov Functions. CDC 2018 - 57th IEEE Conference on Decision and Control, Dec 2018, Miami Beach, United States. ⟨hal-01888526⟩
80 Consultations
326 Téléchargements
