Deep Ensemble Effectively and Efficiently for Vehicle Instance Retrieval - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Zhengyan Ding
  • Fonction : Auteur
  • PersonId : 1037185
Xiaoteng Zhang
  • Fonction : Auteur
  • PersonId : 1037186
Shaoxi Xu
  • Fonction : Auteur
  • PersonId : 1037187
Lei Song
  • Fonction : Auteur
  • PersonId : 1037188
Na Duan
  • Fonction : Auteur
  • PersonId : 1037189
This paper aims to highlight instance retrieval tasks centered around ‘vehicle’, due to its wide range of applications in surveillance scenario. Recently, image representations based on the convolutional neural network (CNN) have achieved significant success for visual recognition, including instance retrieval. However, many previous retrieval methods have not exploit the ensemble abilities of different models, which achieve limited accuracy since a certain kind of visual representation is not comprehensive. So we propose a Deep Ensemble Efficiently and Effectively (DEEE) framework, to preserve the impressive performance of deep representations and combine various deep architectures in a complementary way. It is demonstrated that a large improvement can be acquired with slight increase on computation. Finally, we evaluate the performance on two public vehicle datasets, VehicleID and VeRi, both outperforming state-of-the-art methods by a large margin.
470174_1_En_17_Chapter.pdf (581.62 Ko) Télécharger le fichier
hal-01888642 , version 1 (05-10-2018)
Paternité
Zhengyan Ding, Xiaoteng Zhang, Shaoxi Xu, Lei Song, Na Duan. Deep Ensemble Effectively and Efficiently for Vehicle Instance Retrieval. 11th International Conference on Research and Practical Issues of Enterprise Information Systems (CONFENIS), Oct 2017, Shanghai, China. pp.192-201, ⟨10.1007/978-3-319-94845-4_17⟩. ⟨hal-01888642⟩
84 Consultations
43 Téléchargements
