Differentiator application in altitude control for an indoor blimp robot - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Control Année : 2018
This paper presents design of altitude controller with disturbance compensation for an indoor blimp robot and its realisation. Due to hardware restrictions, the altitude control behaviour of blimp is modelled as a switched system with a constant time-delay complemented with uncertain bounded disturbances. In order to achieve state estimation, four differentiators are applied and compared, then HOMD (homo-geneous finite-time) differentiator is chosen as an observer for vertical velocity and switching signal estimation. Next, a predictor-based controller is conceived, and in order to compensate the perturbation, the method for disturbance evaluation is designed still with the help of HOMD differentiator. Control scheme is implemented by Matlab Simulink, and finally, the performance of blimp altitude controller is verified in experiments.
_IJC_authorVersion.pdf (1.44 Mo) Télécharger le fichier
hal-01889244 , version 1 (05-10-2018)
Yue Wang, Gang Zheng, Denis Efimov, Wilfrid Perruquetti. Differentiator application in altitude control for an indoor blimp robot. International Journal of Control, 2018, 91 (9), pp.2121 - 2130. ⟨10.1080/00207179.2018.1441549⟩. ⟨hal-01889244⟩
226 Consultations
344 Téléchargements
