Biclustering Based on FCA and Partition Pattern Structures for Recommendation Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Nyoman Juniarta
Victor Codocedo
Miguel Couceiro
Amedeo Napoli
This paper focuses on item recommendation for visitors in a museum within the framework of European Project CrossCult about cultural heritage. We present a theoretical research work about recommendation using biclustering. Our approach is based on biclustering using FCA and partition pattern structures. First, we recall a previous method of recommendation based on constant-column biclusters. Then, we propose an alternative approach that incorporates an order information and that uses coherent-evolution-on-columns biclusters. This alternative approach shares some common features with sequential pattern mining. Finally, given a dataset of visitor trajectories, we indicate how these approaches can be used to build a collaborative recommendation strategy.
nfmcp_nyoman.pdf (328.82 Ko) Télécharger le fichier
hal-01889384 , version 1 (06-10-2018)
  • HAL Id : hal-01889384 , version 1
Nyoman Juniarta, Victor Codocedo, Miguel Couceiro, Amedeo Napoli. Biclustering Based on FCA and Partition Pattern Structures for Recommendation Systems. NFMCP 2018 - 7th International Workshop on New Frontiers in Mining Complex Patterns, Sep 2018, Dublin, Ireland. ⟨hal-01889384⟩
173 Consultations
247 Téléchargements
