Biclustering Based on FCA and Partition Pattern Structures for Recommendation Systems
This paper focuses on item recommendation for visitors in a museum within the framework of European Project CrossCult about cultural heritage. We present a theoretical research work about recommendation using biclustering. Our approach is based on biclustering using FCA and partition pattern structures. First, we recall a previous method of recommendation based on constant-column biclusters. Then, we propose an alternative approach that incorporates an order information and that uses coherent-evolution-on-columns biclusters. This alternative approach shares some common features with sequential pattern mining. Finally, given a dataset of visitor trajectories, we indicate how these approaches can be used to build a collaborative recommendation strategy.
Domains
Computer Science [cs]
