FEM-based Deformation Control for Dexterous Manipulation of 3D Soft Objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
In this paper, a method for dexterous manipulation of 3D soft objects for real-time deformation control is presented, relying on Finite Element modelling. The goal is to generate proper forces on the fingertips of an anthropomor-phic device during in-hand manipulation to produce desired displacements of selected control points on the object. The desired motions of the fingers are computed in real-time as an inverse solution of a Finite Element Method (FEM), the forces applied by the fingertips at the contact points being modelled by Lagrange multipliers. The elasticity parameters of the model are preliminarly estimated using a vision system and a force sensor. Experimental results are shown with an underactuated anthropomorphic hand that performs a manipulation task on a soft cylindrical object.
manipulation_of_def_objects_1.pdf (3.93 Mo) Télécharger le fichier
hal-01889783 , version 1 (08-10-2018)
  • HAL Id : hal-01889783 , version 1
Fanny Ficuciello, Alessandro Migliozzi, Eulalie Coevoet, Antoine Petit, Christian Duriez. FEM-based Deformation Control for Dexterous Manipulation of 3D Soft Objects. IROS 2018 - IEEE/RSJ International Conference on Intelligent Robots and Systems, Oct 2018, Madrid, Spain. ⟨hal-01889783⟩
308 Consultations
820 Téléchargements
