Which Input Abstraction is Better for a Robot Syntax Acquisition Model? Phonemes, Words or Grammatical Constructions?
There has been a considerable progress these last years in speech recognition systems [13]. The word recognition error rate went down with the arrival of deep learning methods. However, if one uses cloud-based speech API and integrates it inside a robotic architecture [33], one still encounters considerable cases of wrong sentences recognition. Thus speech recognition can not be considered as solved especially when an utterance is considered in isolation of its context. Particular solutions, that can be adapted to different Human-Robot Interaction applications and contexts, have to be found. In this perspective, the way children learn language and how our brains process utterances may help us improve how robot process language. Getting inspiration from language acquisition theories and how the brain processes sentences we previously developed a neuro-inspired model of sentence processing. In this study, we investigate how this model can process different levels of abstractions as input: sequences of phonemes, sequences of words or grammatical constructions. We see that even if the model was only tested on grammatical constructions before, it has better performances with words and phonemes inputs.
paper_main.pdf (654.65 Ko)
Télécharger le fichier
Hinaut2018_ICDL-epirob__supp_mat.pdf (140.49 Ko)
