A reduced Hartree–Fock model of slice-like defects in the Fermi sea - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinearity Année : 2020
Studying the electronic structure of defects in materials is an important subject in condensed matter physics. From a mathematical point of view, nonlinear mean-field models of localized defects in insulators are well understood. We present here a mean-field model to study a particular instance of extended defects in metals. These extended defects typically correspond to taking out a slab of finite width in the three-dimensional homogeneous electron gas. We work in the framework of the reduced Hartree-Fock model with either Yukawa or Coulomb interactions. Using techniques developed to study local perturbations of the free-electron gas, we show that our model admits minimizers, and that Yukawa ground state energies and density matrices converge to ground state Coulomb energies and density matrices as the Yukawa parameter tends to zero. We moreover present numerical simulations where we observe Friedel oscillations in the total electronic density.
hal-01891488 , version 1 (09-10-2018)
Eric Cancès, Ling-Ling Cao, Gabriel Stoltz. A reduced Hartree–Fock model of slice-like defects in the Fermi sea. Nonlinearity, 2020, 33 (1), pp.156-195. ⟨10.1088/1361-6544/ab4c7d⟩. ⟨hal-01891488⟩
81 Consultations
0 Téléchargements
