Convergence and a posteriori error analysis for energy-stable finite element approximations of degenerate parabolic equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
We propose a finite element scheme for numerical approximation of degenerate parabolic problems in the form of a nonlinear anisotropic Fokker-Planck equation. The scheme is energy-stable, only involves physically motivated quantities in its definition, and is able to handle general unstructured grids. Its convergence is rigorously proven thanks to compactness arguments, under very general assumptions. Although the scheme is based on Lagrange finite elements of degree 1, it is locally conservative after a local postprocess giving rise to an equilibrated flux. This also allows to derive a guaranteed a posteriori error estimate for the approximate solution. Numerical experiments are presented in order to give evidence of a very good behavior of the proposed scheme in various situations involving strong anisotropy and drift terms.
CNV.pdf (3.4 Mo) Télécharger le fichier
hal-01894884 , version 1 (12-10-2018)
hal-01894884 , version 2 (30-06-2020)
  • HAL Id : hal-01894884 , version 1
Clément Cancès, Flore Nabet, Martin Vohralík. Convergence and a posteriori error analysis for energy-stable finite element approximations of degenerate parabolic equations. 2019. ⟨hal-01894884v1⟩
Collections
UNIV-PARIS-SACLAY
394 Consultations
408 Téléchargements
