q-BOREL-LAPLACE SUMMATION FOR q-DIFFERENCE EQUATIONS WITH TWO SLOPES - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Difference Equations and Applications Année : 2016
In this paper, we consider linear q-difference systems with coefficients that are germs of meromorphic functions, with Newton polygon that has two slopes. Then, we explain how to compute similar meromorphic gauge transformations than those appearing in the work of Bugeaud, using a q-analogue of the Borel-Laplace summation.
qsumbug.pdf (338.81 Ko) Télécharger le fichier
hal-01897323 , version 1 (17-10-2018)
Thomas Dreyfus, Anton Eloy. q-BOREL-LAPLACE SUMMATION FOR q-DIFFERENCE EQUATIONS WITH TWO SLOPES. Journal of Difference Equations and Applications, 2016, 22 (10), pp.1501 - 1511. ⟨10.1080/10236198.2016.1209192⟩. ⟨hal-01897323⟩
218 Consultations
306 Téléchargements
