Ensuring data freshness for periodic real-time tasks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Automotive systems are composed of embedded applications which are continuously exchanging real-time data. Exchanged data are then propagated within a list of applications involved at different rates in the definition of a function. Different rates of executions for the applications provoke over-and/or under-sampling of data and the age of the data has an obvious impact on the driving decisions. Ensuring that the appropriate data are consumed by an application motivates to maintain the freshness or the temporal validity of real-time data. In this paper we propose a method calculating the freshness of the data for real-time systems where multi-rate sampling of data is considered.
RTNS_JWRTC_2018.pdf (713.09 Ko) Télécharger le fichier
hal-01900328 , version 1 (21-10-2018)
  • HAL Id : hal-01900328 , version 1
Evariste Ntaryamira, Cristian Maxim, Liliana Cucu-Grosjean. Ensuring data freshness for periodic real-time tasks. Junior Workshop: JRWRTC 2018 - 12th Junior Researcher Workshop on Real-Time Computing, Oct 2018, Poitiers, France. ⟨hal-01900328⟩
260 Consultations
190 Téléchargements
