A verified SAT solver with watched literals using imperative HOL - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Based on our earlier formalization of conflict-driven clause learning (CDCL) in Isabelle/HOL, we refine the CDCL calculus to add a crucial optimization: two watched literals. We formalize the data structure and the invariants. Then we refine the calculus to obtain an executable SAT solver. Through a chain of refinements carried out using the Isa-belle Refinement Framework, we target Imperative HOL and extract imperative Standard ML code. Although our solver is not competitive with the state of the art, it offers acceptable performance for some applications, and heuristics can be added to improve it further.
sat_2wl_paper.pdf (697.97 Ko) Télécharger le fichier
hal-01904647 , version 1 (25-10-2018)
Mathias Fleury, Jasmin Christian Blanchette, Peter Lammich. A verified SAT solver with watched literals using imperative HOL. CPP 2018 - The 7th ACM SIGPLAN International Conference on Certified Programs and Proofs, Jan 2018, Los Angeles, United States. ⟨10.1145/3167080⟩. ⟨hal-01904647⟩
143 Consultations
273 Téléchargements
