Internal rapid stabilization of a 1-D linear transport equation with a scalar feedback - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
We use the backstepping method to study the stabilization of a 1-D linear transport equation on the interval (0, L), by controlling the scalar amplitude of a piecewise regular function of the space variable in the source term. We prove that if the system is controllable in a periodic Sobolev space of order greater than 1, then the system can be stabilized exponentially in that space and, for any given decay rate, we give an explicit feedback law that achieves that decay rate.
_piecewise__Internal_rapid_stabilization_of_the_1_D_linear_transport_equation_using_the_backstepping_method__Copy___Copy_.pdf (452.56 Ko) Télécharger le fichier
hal-01905098 , version 1 (25-10-2018)
hal-01905098 , version 2 (18-11-2019)
hal-01905098 , version 3 (04-09-2020)
Christophe Zhang. Internal rapid stabilization of a 1-D linear transport equation with a scalar feedback. 2018. ⟨hal-01905098v1⟩
281 Consultations
164 Téléchargements
