Convex Optimisation Method for Matching Filters Synthesis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
In this paper, a certified synthesis technique is presented for the design of matching filters that combines convex optimisation with the Fano-Youla matching theory. This technique is applicable to any rational load and provides lower hard bounds for the best matching level, as well as a practical synthesis of a matching filter approaching those bounds. Furthermore, if the load is a rational function of degree 1, the optimal matching filter is synthesized, yielding in this case an extension of the classical filter synthesis for resistive loads. As example, a dual-band matching filter is conceived for a dual-band antenna. Additionally a single-band filter is implemented in SIW technology to match a single-band antenna.
IWMF2018.pdf (323.87 Ko) Télécharger le fichier
hal-01778631 , version 1 (01-06-2018)
  • HAL Id : hal-01778631 , version 1
David Martínez Martínez, Gibin Bose, Fabien Seyfert, Martine Olivi. Convex Optimisation Method for Matching Filters Synthesis. IWMF 2018 - 7th International Workshop on Microwave Filters, ESA; CNES, Apr 2018, Noordwijk, Netherlands. ⟨hal-01778631⟩
348 Consultations
309 Téléchargements
