Statistical Analysis of the Multichannel Wiener Filter Using a Bivariate Normal Distribution for Sample Covariance Matrices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE/ACM Transactions on Audio, Speech and Language Processing Année : 2018
This paper studies the statistical performance of the multichannel Wiener filter (MWF) when the weights are computed using estimates of the sample covariance matrices of the noisy and the noise signals. It is well known that the optimal weights of the minimum variance distortionless response (MVDR) beamformer are only determined by the noisy sample covariance matrix or the noise sample covariance matrix, while those of the MWF are determined by both of them. Therefore, the difficulty increases dramatically in statistically analyzing the MWF when compared to analyzing the MVDR, where the main reason is that expressing the general joint probability density function (p.d.f.) of the two sample covariance matrices presented a hitherto unsolved problem, to the best of our knowledge. For a deeper insight into the statistical performance of the MWF, this paper first introduces a bivariate normal distribution to approximately model the joint p.d.f. of the noisy and the noise sample covariance matrices. Each sample covariance matrix is approximately modeled by a random scalar multiplied by its true covariance matrix. This approximation is designed to preserve both the bias and the mean squared error of the matrix with respect to a natural distance on covariance matrices. The correlation of the bivariate normal distribution, referred to as the sample covariance matrices intrinsic correlation coefficient, captures all second-order dependencies of the noisy and the noise sample covariance matrices. By using the proposed bivariate normal distribution, the performance of the MWF can be predicted from the derived analytical expressions and many interesting results are revealed. As an example, the theoretical analysis demonstrates that the MWF performance may degrade in terms of noise reduction and signal-to-noise-ratio improvement when using more sensors in some noise scenarios.
FINAL VERSION.pdf (1.87 Mo) Télécharger le fichier
hal-01909612 , version 1 (05-11-2018)
Chengshi Zheng, Antoine Deleforge, Xiaodong Li, Walter Kellermann. Statistical Analysis of the Multichannel Wiener Filter Using a Bivariate Normal Distribution for Sample Covariance Matrices. IEEE/ACM Transactions on Audio, Speech and Language Processing, 2018, 26 (5), pp.951 - 966. ⟨10.1109/TASLP.2018.2800283⟩. ⟨hal-01909612⟩
122 Consultations
427 Téléchargements
