Cartesian Systemic Pulsation – A Model for Evolutive Improvement of Incomplete Symbiotic Recursive Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal On Advances in Intelligent Systems Année : 2018
Developing and using Symbiotic Recursive Systems (SRS) concerns various incompletely defined domains requiring handling prevention and control. This means that, in the innovation process, it is important to avoid decline and obsolescence as it happens with modern paradigms of innovation. This paper presents the specificities of SRS that call for a new model of evolutive improvement. Such a new model needs to handle prevention and control in SRS as well as in the improvement process. The paper presents such a model we call ‘Pulsation’. Symbiotic Recursive Pulsative Systems are then SRS including the process of Pulsation.
franova-kodratoff IARIA Journal 2018 18019 upload definitif.pdf (412.37 Ko) Télécharger le fichier
hal-01912036 , version 1 (05-11-2018)
  • HAL Id : hal-01912036 , version 1
Marta Franova, Yves Kodratoff. Cartesian Systemic Pulsation – A Model for Evolutive Improvement of Incomplete Symbiotic Recursive Systems. International Journal On Advances in Intelligent Systems, 2018. ⟨hal-01912036⟩
91 Consultations
59 Téléchargements
