On homomorphisms of planar signed graphs and absolute cliques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
A simple signed graph ($G,Σ$) is a simple graph with a + or a − sign assigned to each of its edges where $Σ$ denotes the set of negative edges. A closed-walk is unbalanced if it has an odd number of negative edges, it is balanced otherwise. Homomorphisms of simple signed graphs are adjacency and balance of a closed-walk preserving vertex mappings. Naserasr, Rollova and Sopena (Journal of Graph Theory 2015) posed the important question of finding out the minimum |V(H)| such that any planar signed graph ($G,Σ$) admits a homomorphism to ($H,Π$). It is known that if this minimum value is equal to 10, then every planar signed graph must admit homomorphism to a particular unique signed graph ($P+9 ,Γ+$) on 10 vertices. A graph G is an underlying absolute signed clique if there exists a signed graph ($G,Σ$) which does not admit any homomorphism to any signed graph ($H,Π$) with $|V(H)|<|V(G)|$. We characterize all underlying absolute signed planar cliques upto spanning subgraph inclusion. Furthermore, we show that every signed planar graph having underlying graphs obtained by (repeated, finite) k-clique sums ($k≤3$) of underlying absolute signed planar cliques admits a homomorphism to (P+9 ,Γ+). Based on this evidence, we conjecture that every planar signed graph admits a homomorphism to ($P+9 ,Γ+$).
NSS_v7.pdf (254.97 Ko) Télécharger le fichier
hal-01919007 , version 1 (12-11-2018)
hal-01919007 , version 2 (09-04-2020)
  • HAL Id : hal-01919007 , version 1
Julien Bensmail, Soumen Nandi, Mithun Roy, Sagnik Sen. On homomorphisms of planar signed graphs and absolute cliques. 2018. ⟨hal-01919007v1⟩
232 Consultations
157 Téléchargements
