Efficient Global Optimization using Deep Gaussian Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Efficient Global Optimization (EGO) is widely used for the optimization of computationally expensive black-box functions. It uses a surrogate modeling technique based on Gaussian Processes (Kriging). However, due to the use of a stationary covariance, Kriging is not well suited for approximating non stationary functions. This paper explores the integration of Deep Gaussian processes (DGP) in EGO framework to deal with the non-stationary issues and investigates the induced challenges and opportunities. Numerical experimentations are performed on analytical problems to highlight the different aspects of DGP and EGO.
conference_071817.pdf (939.98 Ko) Télécharger le fichier
hal-01919795 , version 1 (31-08-2020)
  • HAL Id : hal-01919795 , version 1
Ali Hebbal, Loïc Brevault, Mathieu Balesdent, El-Ghazali Talbi, Nouredine Melab. Efficient Global Optimization using Deep Gaussian Processes. CEC 2018 - Congress on Evolutionary Computation, Jul 2018, Rio de Janeiro, Brazil. ⟨hal-01919795⟩
179 Consultations
1314 Téléchargements
