Global sensitivity analysis for models described by stochastic differential equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Methodology and Computing in Applied Probability Année : 2020
UQ_EDS1_etore_prieur_nov2018.pdf (302.37 Ko) Télécharger le fichier
hal-01926919 , version 1 (19-11-2018)
hal-01926919 , version 2 (17-07-2020)
Pierre Etoré, Clémentine Prieur, Dang Khoi Pham, Long Li. Global sensitivity analysis for models described by stochastic differential equations. Methodology and Computing in Applied Probability, 2020, pp.803-831. ⟨10.1007/s11009-019-09732-6⟩. ⟨hal-01926919v1⟩
531 Consultations
672 Téléchargements
