Numerical analysis for an energy-stable total discretization of a poromechanics model with inf-sup stability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Acta Mathematicae Applicatae Sinica Année : 2019
We consider a previously proposed general nonlinear poromechanical formulation, and we derive a linearized version of this model. For this linearized model, we obtain an existence result and we propose a complete discretization strategy - in time and space - with a special concern for issues associated with incompressible or nearly-incompressible behavior. We provide a detailed mathematical analysis of this strategy, the main result being an error estimate uniform with respect to the compressibility parameter. We then illustrate our approach with detailed simulation results and we numerically investigate the importance of the assumptions made in the analysis, including the fulfillment of specific inf-sup conditions.
ThermoPerfAnalyze.pdf (1.16 Mo) Télécharger le fichier
hal-01928312 , version 1 (20-11-2018)
hal-01928312 , version 2 (11-01-2019)
Bruno Burtschell, Philippe Moireau, Dominique Chapelle. Numerical analysis for an energy-stable total discretization of a poromechanics model with inf-sup stability. Acta Mathematicae Applicatae Sinica, 2019, 35 (1), pp.28-53. ⟨10.1007/s10255-019-0799-5⟩. ⟨hal-01928312v2⟩
217 Consultations
256 Téléchargements
