Intensity-based matching and registration for 3D correlative microscopy with large discrepancies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Correlative microscopy, especially light and electron microscopy (CLEM), enables the study of cells and subcellular elements in complementary ways, provided a reliable registration between images is efficiently achievable. We propose a general automatic registration method. Due to large discrepancies in appearance, field-of-view, resolution and position, a pre-alignment stage is required before any 3D fine registration stage. We define an intensity-based method for both stages, which leverages a common representation of the two involved image modalities. We report experimental results on different real datasets of 3D correlative microscopy, demonstrating time efficiency and overlay accuracy.
isbi2018vf.pdf (2.76 Mo) Télécharger le fichier
hal-01930740 , version 1 (22-11-2018)
Bertha Mayela Toledo Acosta, Xavier Heiligenstein, Grégoire Malandain, Patrick Bouthemy. Intensity-based matching and registration for 3D correlative microscopy with large discrepancies. ISBI 2018 - IEEE 15th International Symposium on Biomedical Imaging, Apr 2018, Washington, United States. pp.493-496, ⟨10.1109/ISBI.2018.8363623⟩. ⟨hal-01930740⟩
181 Consultations
209 Téléchargements
