Autotuning and Adaptivity in Energy Efficient HPC Systems: The ANTAREX Toolbox - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
João Bispo
  • Fonction : Auteur
  • PersonId : 1024465
Loïc Besnard
  • Fonction : Auteur
  • PersonId : 831485
Nico Sanna
  • Fonction : Auteur
Carlo Cavazzoni
  • Fonction : Auteur
Designing and optimizing applications for energy-efficient High Performance Computing systems up to the Exascale era is an extremely challenging problem. This paper presents the toolbox developed in the ANTAREX European project for autotuning and adaptivity in energy efficient HPC systems. In particular, the modules of the ANTAREX toolbox are described as well as some preliminary results of the application to two target use cases.
Autre [cs.OH]
CF2018-ok.pdf (1.31 Mo) Télécharger le fichier
hal-01932706 , version 1 (23-11-2018)
Cristina Silvano, Gianluca Palermo, Giovanni Agosta, Amir H Ashouri, Davide Gadioli, et al.. Autotuning and Adaptivity in Energy Efficient HPC Systems: The ANTAREX Toolbox. CF 2018 - 15th ACM International Conference on Computing Frontiers, May 2018, Ischia, Italy. pp.270-275, ⟨10.1145/3203217.3205338⟩. ⟨hal-01932706⟩
231 Consultations
178 Téléchargements
