Lifted and geometric differentiability of the squared quadratic Wasserstein distance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Probability and Statistics Année : 2020
In this paper, we remark that any optimal coupling for the quadratic Wasserstein distance W22(μ,ν) between two probability measures μ and ν with finite second order moments on Rd is the composition of a martingale coupling with an optimal transport map T. We check the existence of an optimal coupling in which this map gives the unique optimal coupling between μ and T#μ. Next, we prove that σ↦W22(σ,ν) is differentiable at μ in the Lions~\cite{Lions} and the geometric senses iff there is a unique optimal coupling between μ and ν and this coupling is given by a map. Besides, we give a self-contained proof that mere Fréchet differentiability of a law invariant function F on L2(Ω,P;Rd) is enough for the Fréchet differential at X to be a measurable function of X.
hal-01934705 , version 1 (26-11-2018)
hal-01934705 , version 2 (16-11-2020)
Aurélien Alfonsi, Benjamin Jourdain. Lifted and geometric differentiability of the squared quadratic Wasserstein distance. ESAIM: Probability and Statistics, 2020, ⟨10.1051/ps/2020013⟩. ⟨hal-01934705v1⟩
183 Consultations
445 Téléchargements
