Preprints, Working Papers, ...
Adaptive density estimation on bounded domains under mixing conditions
Abstract : In this article, we propose a new adaptive estimator for compact supported density functions, in the framework of multivariate mixing processes. Several procedures have been proposed in the literature to tackle the boundary bias issue encountered using classical kernel estimators on the unit d-dimensional hypercube. We extend such results to more general bounded domains in R d. We introduce a specific family of kernel-type estimators adapted to the estimation of compact supported density functions. We then propose a data-driven Goldenshluger and Lepski type procedure to jointly select a kernel and a bandwidth. We prove the optimality of our procedure in the adaptive framework, stating an oracle-type inequality. We illustrate the good behavior of our new class of estimators on simulated data. Finally, we apply our procedure to a real dataset. MSC 2010 subject classifications: Primary 62G05, 62G07, 60K35.
Document type :
Complete list of metadatas
Cited literature [41 references]  Display  Hide  Download
https://hal.inria.fr/hal-01934913
Contributor : Clémentine Prieur <>
Submitted on : Monday, November 26, 2018 - 1:00:31 PM
Last modification on : Friday, July 10, 2020 - 7:58:56 AM
Long-term archiving on: : Wednesday, February 27, 2019 - 2:06:39 PM
File
article.pdf
Identifiers
  • HAL Id : hal-01934913, version 1
Citation
Karine Bertin, Nicolas Klutchnikoff, José León, Clémentine Prieur. Adaptive density estimation on bounded domains under mixing conditions. 2018. ⟨hal-01934913v1⟩
Share
Metrics
Record views
73
Files downloads
20
