Low-rankness transfer for denoising Sentinel-1 SAR images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
This paper introduces a new algorithm for denoising SAR images. It is directly applicable to Sentinel-1 GRD images, without the need for single-look complex operations. The algorithm builds on the non-local patch matching idea for statistical denoising, similar to the SAR-BM3D and NL-SAR algorithms, but introduces two corrections : 1. A non-uniform prior for the reflectance values is used for the patch matching, thus allowing a better fit to the data, and 2. Denoising is performed in singular values space, with a prior distribution of expected "clean" singular values learned and transfered from optical images. The denoised SAR images show reduced amount of speckle compared to alternative methods.
low-rank_sentinel1_denoising.pdf (2.09 Mo) Télécharger le fichier
hal-01936331 , version 1 (27-11-2018)
  • HAL Id : hal-01936331 , version 1
Nicolas Brodu. Low-rankness transfer for denoising Sentinel-1 SAR images. ISIVC'2018 - 9th International Symposium on Signal, Image, Video and Communications, Nov 2018, Rabat, Morocco. ⟨hal-01936331⟩
Collections
INRIA INRIA2
67 Consultations
110 Téléchargements
