Rotting bandits are not harder than stochastic ones - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In stochastic multi-armed bandits, the reward distribution of each arm is assumed to be stationary. This assumption is often violated in practice (e.g., in recommendation systems), where the reward of an arm may change whenever is selected, i.e., rested bandit setting. In this paper, we consider the non-parametric rotting bandit setting, where rewards can only decrease. We introduce the filtering on expanding window average (FEWA) algorithm that constructs moving averages of increasing windows to identify arms that are more likely to return high rewards when pulled once more. We prove that for an unknown horizon $T$, and without any knowledge on the decreasing behavior of the $K$ arms, FEWA achieves problem-dependent regret bound of $\widetilde{\mathcal{O}}(\log{(KT)}),$ and a problem-independent one of $\widetilde{\mathcal{O}}(\sqrt{KT})$. Our result substantially improves over the algorithm of Levine et al. (2017), which suffers regret $\widetilde{\mathcal{O}}(K^{1/3}T^{2/3})$. FEWA also matches known bounds for the stochastic bandit setting, thus showing that the rotting bandits are not harder. Finally, we report simulations confirming the theoretical improvements of FEWA.
seznec2019rotting.pdf (7.26 Mo) Télécharger le fichier
hal-01936894 , version 1 (27-11-2018)
hal-01936894 , version 2 (09-05-2020)
  • HAL Id : hal-01936894 , version 2
Julien Seznec, Andrea Locatelli, Alexandra Carpentier, Alessandro Lazaric, Michal Valko. Rotting bandits are not harder than stochastic ones. International Conference on Artificial Intelligence and Statistics, 2019, Naha, Japan. ⟨hal-01936894v2⟩
219 Consultations
214 Téléchargements
