Bilevel Network Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2021
This chapter is devoted to network design problems involving conflicting agents, referred to as the designer and the users, respectively. Such problems are best cast into the framework of bilevel programming, where the designer anticipates the reaction or rational users to its course of action, and fits many situations of interest. In this chapter, we consider four applications of very different nature, with a special focus on algorithmic issues.
chapter-bilevel network design-final-062018.pdf (182.41 Ko) Télécharger le fichier
hal-01937014 , version 1 (27-11-2018)
Martine Labbé, Patrice Marcotte. Bilevel Network Design. Teodor Gabriel Crainic, Michel Gendreau, Bernard Gendron. Network Design with Applications to Transportation and Logistics, Springer, pp.255-281, 2021, ⟨10.1007/978-3-030-64018-7_9⟩. ⟨hal-01937014⟩
92 Consultations
398 Téléchargements
