Blockchain orchestration and experimentation framework: A case study of KYC - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Conducting experiments to evaluate blockchain ap- plications is a challenging task for developers, because there is a range of configuration parameters that control blockchain environments. Many public testnets (e.g. Rinkeby Ethereum) can be used for testing, however, we cannot adjust their parameters (e.g. Gas limit, Mining difficulty) to further the understanding of the application in question and of the employed blockchain. This paper proposes an easy to use orchestration framework over the Grid’5000 platform. Grid’5000 is a highly reconfigurable and controllable large-scale testbed. We developed a tool that facilitates nodes reservation, deployment and blockchain config- uration over the Grid’5000 platform. In addition, our tool can fine-tune blockchain and network parameters before and between experiments. The proposed framework offers insights for private and consortium blockchain developers to identify performance bottlenecks and to assess the behavior of their applications in different circumstances.
blockchain-orchestration-experimentation.pdf (208.3 Ko) Télécharger le fichier
hal-01939865 , version 1 (29-11-2018)
  • HAL Id : hal-01939865 , version 1
Wazen M Shbair, Mathis Steichen, Jerome Francois, Radu State. Blockchain orchestration and experimentation framework: A case study of KYC. IEEE/IFIP Man2Block 2018 - IEEE/IFIP Network Operations and Management Symposium, Apr 2018, Taipei, Taiwan. ⟨hal-01939865⟩
823 Consultations
1563 Téléchargements
