Discriminant chronicle mining - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2019
Sequential pattern mining attempts to extract frequent behaviors from a sequential dataset. When sequences are labeled, it is interesting to extract behaviors that characterize each sequence class. This task is called discriminant pattern mining. In this paper, we introduce discriminant chronicle mining. Conceptually, a chronicle is a temporal graph whose vertices are events and whose edges represent numerical temporal constraints between these events. We propose DCM, an algorithm that mines discriminant chronicles. It is based on rule learning methods that extract the temporal constraints. Computational performances and discriminant power of extracted chronicles are evaluated on synthetic and real data. Finally, we apply this algorithm to the case study consisting in analyzing care pathways of epileptic patients.
AKDM_final.pdf (410.72 Ko) Télécharger le fichier
hal-01940146 , version 1 (30-11-2018)
Yann Dauxais, David Gross-Amblard, Thomas Guyet, André Happe. Discriminant chronicle mining. B. Pinaud; F. Guillet; F. Gandon and C. Largeron. Advances in Knowledge Discovery and Management (vol 8), Springer, Cham, pp.89-118, 2019, Advances in Knowledge Discovery and Management, 978-3-030-18128-4. ⟨10.1007/978-3-030-18129-1_5⟩. ⟨hal-01940146⟩
286 Consultations
250 Téléchargements
