Optimization of a discontinuous finite element solver with OpenCL and StarPU - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
schnaps is a finite element solver designed to simulate various physical phenomena. It is designed to run on hybrid computers made of several CPUs and GPUs. In order to address the hybrid architectures we rely on the StarPU runtime. StarPU allows to optimize in an incre- mental way a sequential algorithm in order to migrate to multicore parallelism and then to hybrid computing with OpenCL accelerators. StarPU proposes several task scheduling strategies in or- der to efficiently exploit the available computing power. We present the design of schnaps and the performance gain that we have obtained in electromagnetic simulations thanks to OpenCL codelets.
schnaps_opencl_helluy.pdf (537.53 Ko) Télécharger le fichier
hal-01942863 , version 1 (03-12-2018)
hal-01942863 , version 2 (08-07-2019)
hal-01942863 , version 3 (23-01-2020)
  • HAL Id : hal-01942863 , version 2
Bérenger Bramas, Philippe Helluy, Laura Mendoza, Bruno Weber. Optimization of a discontinuous finite element solver with OpenCL and StarPU. 2019. ⟨hal-01942863v2⟩
371 Consultations
344 Téléchargements
