Cross-layer QoS-Aware Resource Allocation for IoT-Enabled Service Choreographies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Resource allocation for distributed systems is a well-known approach to deal with quality of service requirements. However, existing approaches do not consider the effects of resource allocation at the different levels of a system, especially when considering the end-to-end behavior of distributed compositions such as service choreographies. Based on our previous research on the optimized and QoS-aware resource allocation for service choreographies and publish-subscribe brokers, we outline a novel approach that integrates the treatment of resource allocation at both levels in order to yield a more precise control over end-to-end QoS. The paper presents an early architecture and discusses some of the main challenges towards realizing the approach.
m4iot_2018_Fabio.pdf (882.24 Ko) Télécharger le fichier
hal-01943541 , version 1 (03-12-2018)
  • HAL Id : hal-01943541 , version 1
Fábio M. Costa, Nikolaos Georgantas, Raphael Gomes, Ricardo da Rocha, Georgios Bouloukakis. Cross-layer QoS-Aware Resource Allocation for IoT-Enabled Service Choreographies. The 5th International Workshop on Middleware and Applications for the Internet of Things (M4IoT), Dec 2018, Rennes, France. ⟨hal-01943541⟩
34 Consultations
133 Téléchargements
