Continuous and discrete-time stability of a robust set-valued nested controller - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
We propose a set-valued controller with a signum multifunction nested inside another one. We prove that the controller is well posed and achieves robust ultimate boundedness in the presence of mismatched, non-vanishing disturbances. Even more, the selected output can be made arbitrarily small. Also, by applying an implicit/explicit Euler scheme similar to the one introduced by Acary et al. for matched disturbances, we derive a selection strategy for the discrete-time implementation of the set-valued control law. Simulations demonstrate that the discrete scheme diminishes chattering substantially, compared with a fully explicit method.
Backstepping_04122018.pdf (1.93 Mo) Télécharger le fichier
hal-01944920 , version 1 (05-12-2018)
hal-01944920 , version 2 (26-06-2019)
  • HAL Id : hal-01944920 , version 1
Felix Miranda-Villatoro, Fernando Castaños, Bernard Brogliato. Continuous and discrete-time stability of a robust set-valued nested controller. 2018. ⟨hal-01944920v1⟩
159 Consultations
326 Téléchargements
