Feedback Control Principles for Biological Control of Dengue Vectors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Controlling diseases such as dengue fever, chikungunya and zika fever by introduction of the intracellular parasitic bacterium Wolbachia in mosquito populations which are their vectors, is presently quite a promising tool to reduce their spread. While description of the conditions of such experiments has received ample attention from biologists, entomologists and applied mathematicians, the issue of effective scheduling of the releases remains an interesting problem for Control theory. Having in mind the important uncertainties present in the dynamics of the two populations in interaction, we attempt here to identify general ideas for building release strategies, which should apply to several models and situations. These principles are exemplified by two interval observer-based feedback control laws whose stabilizing properties are demonstrated when applied to a model retrieved from Bliman et al., 2018. Crucial use is made of the theory of monotone dynamical systems.
ECC2019_SHORT.pdf (506.98 Ko) Télécharger le fichier
hal-01944958 , version 1 (05-12-2018)
hal-01944958 , version 2 (05-03-2019)
  • HAL Id : hal-01944958 , version 2
Pierre-Alexandre Bliman. Feedback Control Principles for Biological Control of Dengue Vectors. European Control Conference ECC19, Jun 2019, Naples, Italy. pp.6. ⟨hal-01944958v2⟩
168 Consultations
150 Téléchargements
