Robust Bregman Clustering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Using a trimming approach, we investigate a k-means type method based on Bregman divergences for clustering data possibly corrupted with clutter noise. The main interest of Bregman divergences is that the standard Lloyd algorithm adapts to these distortion measures, and they are well-suited for clustering data sampled according to mixture models from exponential families. We prove that there exists an optimal codebook, and that an empirically optimal codebook converges a.s. to an optimal codebook in the distortion sense. Moreover, we obtain the sub-Gaussian rate of convergence for k-means 1 √ n under mild tail assumptions. Also, we derive a Lloyd-type algorithm with a trimming parameter that can be selected from data according to some heuristic, and present some experimental results.
RobustBregmanClustering.pdf (819.05 Ko) Télécharger le fichier
hal-01948051 , version 1 (11-12-2018)
hal-01948051 , version 2 (10-04-2020)
hal-01948051 , version 3 (09-09-2020)
Claire Brécheteau, Aurélie Fischer, Clément Levrard. Robust Bregman Clustering. 2018. ⟨hal-01948051v1⟩
Collections
UNIV-PARIS7 LMJL
465 Consultations
459 Téléchargements
