Energy preserving methods for nonlinear Schrödinger equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IMA Journal of Numerical Analysis Année : 2021
This paper is concerned with the numerical integration in time of nonlinear Schrödinger equations using different methods preserving the energy or a discrete analog of it. The Crank-Nicolson method is a well known method of order 2 but is fully implicit and one may prefer a linearly implicit method like the relaxation method introduced in [10] for the cubic nonlinear Schrödinger equation. This method is also an energy preserving method and numerical simulations have shown that its order is 2. In this paper we give a rigorous proof of the order of this relaxation method and propose a generalized version that allows to deal with general power law nonlinearites. Numerical simulations for different physical models show the efficiency of these methods.
main.pdf (5.67 Mo) Télécharger le fichier
hal-01951527 , version 1 (11-12-2018)
Christophe Besse, Stephane Descombes, Guillaume Dujardin, Ingrid Lacroix-Violet. Energy preserving methods for nonlinear Schrödinger equations. IMA Journal of Numerical Analysis, 2021, 41 (1), pp.618-653. ⟨10.1093/imanum/drz067⟩. ⟨hal-01951527⟩
434 Consultations
327 Téléchargements
