Private Information Retrieval Schemes with With Product-Matrix MBR Codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
A private information retrieval (PIR) scheme allows a user to retrieve a file from a database without revealing any information on the file being requested. As of now, PIR schemes have been proposed for several kinds of storage systems, including replicated and MDS-coded systems. However, the problem of constructing PIR schemes on regenerating codes has been sparsely considered. A regenerating code is a storage code whose codewords are distributed among nodes, enabling efficient storage of files, as well as low-bandwidth retrieval of files and repair of nodes. Minimum-bandwidth regenerating (MBR) codes define a family of regenerating codes allowing a node repair with optimal bandwidth. Rashmi, Shah, and Kumar obtained a large family of MBR codes using the product-matrix (PM) construction. In this work, a new PIR scheme over PM-MBR codes is designed. The inherent redundancy of the PM structure is used to reduce the download communication complexity of the scheme. A lower bound on the PIR capacity of MBR-coded PIR schemes is derived, showing an interesting storage space vs. PIR rate trade-off compared to existing PIR schemes with the same reconstruction capability. The present scheme also outperforms a recent PM-MBR PIR construction of Dorkson and Ng.
Private_Information_Retrieval_with_Regenerating_Codes.pdf (419.92 Ko) Télécharger le fichier
hal-01951956 , version 1 (11-12-2018)
hal-01951956 , version 2 (21-09-2020)
Julien Lavauzelle, Razane Tajeddine, Ragnar Freij-Hollanti, Camilla Hollanti. Private Information Retrieval Schemes with With Product-Matrix MBR Codes. 2020. ⟨hal-01951956v1⟩
357 Consultations
248 Téléchargements
