Abstract : Background and Aims The question of which cellular mechanisms determine the variation in
leaf size has been addressed mainly in plants with simple leaves. It is addressed here in tomato
taking into consideration the expected complexity added by the several lateral appendages
composing the compound leaf, the leaflets.
Methods Leaf and leaflet areas, epidermal cell number and areas, and endoreduplication
(co-)variations were analyzed in Solanum lycopersicum cv. considering heteroblastic series in a
wild-type (Wva106) and an antisense mutant, the Pro35S:Slccs52AAS line, and upon drought
treatments. All plants were grown in an automated phenotyping platform, PHENOPSIS adapted
to host plants grown in 7L pots.
Key results Leaf area, leaflet area and cell number increased with leaf rank until reaching a
plateau. In contrast, cell area slightly decreased and endoreduplication did not follow any trend.
In the transgenic line, leaf area, leaflet areas and cell number of basal leaves were lower than in
the wild-type, but higher in upper leaves. Reciprocally, cell area was higher in basal leaves and
lower in upper ones. When scaled up at the whole sympodial unit, all these traits did not differ
significantly between the transgenic line and the wild-type. In response to drought, leaf area was
reduced with a clear dose effect that was also reported for all size-related traits, including
endoreduplication.
Conclusions These results bring evidence that all leaflets have the same cellular phenotypes than
the leaf they belong to. Consistently with results reported for simple leaves, they show that cell
number rather than cell size determines the final leaf areas and that endoreduplication can be
uncoupled from leaf and cell sizes. Finally, they re-question a whole plant control of cell division
and expansion in leaves when the Wva106 and the Pro35S:Slccs52AAS lines are compared.
