A Branch-Price-and-Cut Procedure for the Discrete Ordered Median Problem
The Discrete Ordered Median Problem (DOMP) is formulated as a set partitioning problem using an exponential number of variables. Each variable corresponds to a set of demand points allocated to the same facility with the information of the sorting position of their corresponding costs. We develop a column generation approach to solve the continuous relaxation of this model. Then, we apply a branch-price-and-cut algorithm to solve small to large sized instances of DOMP in competitive computational time.
Recherche opérationnelle [math.OC]
