Register Optimizations for Stencils on GPUs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
The recent advent of compute-intensive GPU architecture has allowed application developers to explore high-order 3D stencils for better computational accuracy. A common optimization strategy for such stencils is to expose sufficient data reuse by means such as loop unrolling, with the expectation of register-level reuse. However, the resulting code is often highly constrained by register pressure. While current state-of-the-art register allocators are satisfactory for most applications, they are unable to effectively manage register pressure for such complex high-order stencils, resulting in sub-optimal code with a large number of register spills. In this paper, we develop a statement reordering framework that models stencil computations as a DAG of trees with shared leaves, and adapts an optimal scheduling algorithm for minimizing register usage for expression trees. The effectiveness of the approach is demonstrated through experimental results on a range of stencils extracted from application codes.
ppopp18-hal.pdf (775.91 Ko) Télécharger le fichier
hal-01955542 , version 1 (14-12-2018)
  • HAL Id : hal-01955542 , version 1
Prashant Singh, Aravind Sukumaran-Rajam, Atanas Rountev, Fabrice Rastello, Louis-Noël Pouchet, et al.. Register Optimizations for Stencils on GPUs. PPoPP 2018 - 23rd ACM SIGPLAN Symposium on Principles and Practice of Parallel Programming, Feb 2018, Vienna, Austria. pp.1-15. ⟨hal-01955542⟩
226 Consultations
807 Téléchargements
