Hypocoercivity and diffusion limit of a finite volume scheme for linear kinetic equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics of Computation Année : 2020
In this article, we are interested in the asymptotic analysis of a finite volume scheme for one dimensional linear kinetic equations, with either Fokker-Planck or linearized BGK collision operator. Thanks to appropriate uniform estimates, we establish that the proposed scheme is Asymptotic-Preserving in the diffusive limit. Moreover, we adapt to the discrete framework the hypocoercivity method proposed by [J. Dolbeault, C. Mouhot and C. Schmeiser, Trans. Amer. Math. Soc., 367, 6 (2015)] to prove the exponential return to equilibrium of the approximate solution. We obtain decay rates that are bounded uniformly in the diffusive limit. Finally, we present an efficient implementation of the proposed numerical schemes, and perform numerous numerical simulations assessing their accuracy and efficiency in capturing the correct asymptotic behaviors of the models.
main_revised.pdf (1.21 Mo) Télécharger le fichier
Pics/TrendToEq_EquationNonGaussianBGK_InitDat5_Eps1.tex (217.81 Ko) Télécharger le fichier
Pics/TrendToEq_Equationkinetic_FP_InitDat3_Eps1.tex (273.28 Ko) Télécharger le fichier
hal-01957832 , version 1 (17-12-2018)
hal-01957832 , version 2 (16-07-2019)
Marianne Bessemoulin-Chatard, Maxime Herda, Thomas Rey. Hypocoercivity and diffusion limit of a finite volume scheme for linear kinetic equations. Mathematics of Computation, 2020, 89, pp.1093-1133. ⟨10.1090/mcom/3490⟩. ⟨hal-01957832v2⟩
234 Consultations
318 Téléchargements
