On the gap between deterministic and probabilistic joint spectral radii for discrete-time linear systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Given a discrete-time linear switched system $\Sigma(\mathcal A)$ associated with a finite set $\mathcal A$ of matrices, we consider the measures of its asymptotic behavior given by, on the one hand, its deterministic joint spectral radius $\rho_{\mathrm d}(\mathcal A)$ and, on the other hand, its probabilistic joint spectral radii $\rho_{\mathrm p}(\nu,P,\mathcal A)$ for Markov random switching signals with transition matrix $P$ and a corresponding invariant probability $\nu$. Note that $\rho_{\mathrm d}(\mathcal A)$ is larger than or equal to $\rho_{\mathrm p}(\nu,P,\mathcal A)$ for every pair $(\nu, P)$. In this paper, we investigate the cases of equality of $\rho_{\mathrm d}(\mathcal A)$ with either a single $\rho_{\mathrm p}(\nu,P,\mathcal A)$ or with the supremum of $\rho_{\mathrm p}(\nu,P,\mathcal A)$ over $(\nu,P)$ and we aim at characterizing the sets $\mathcal A$ for which such equalities may occur.
gap-preprint.pdf (170.12 Ko) Télécharger le fichier
hal-01961003 , version 1 (19-12-2018)
hal-01961003 , version 2 (15-11-2019)
hal-01961003 , version 3 (04-11-2020)
hal-01961003 , version 4 (16-11-2021)
Yacine Chitour, Guilherme Mazanti, Mario Sigalotti. On the gap between deterministic and probabilistic joint spectral radii for discrete-time linear systems. 2018. ⟨hal-01961003v1⟩
Collections
LM-ORSAY
344 Consultations
235 Téléchargements
