Security Enforcement in IoT Systems using Attack Trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Attack trees are graphical representations of the different scenarios that can lead to a security failure. In this paper we propose a security-based framework for modeling IoT systems where attack trees are defined alongside the model to detect and prevent security risks in the system. A successful attack can be a rare event in the execution of a well designed system. When rare, such attacks are hard to detect with usual model checking techniques. Hence, we use importance splitting as a statistical model checking technique for rare events.
2018_GramSec.pdf (633.92 Ko) Télécharger le fichier
hal-01962089 , version 1 (20-12-2018)
  • HAL Id : hal-01962089 , version 1
Delphine Beaulaton, Najah Ben Said, Ioana Cristescu, Axel Legay, Jean Quilbeuf. Security Enforcement in IoT Systems using Attack Trees. 2018. ⟨hal-01962089⟩
193 Consultations
112 Téléchargements
