Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : Curved mesh generation starting from a P1 mesh relies on mesh deformation and mesh optimization techniques. Mesh optimization techniques consist in locally modifying the mesh in order to improve it with respect to a given quality criterion. This work presents the generalization of two mesh quality-based optimization operators to P2 meshes. The generalized operators consist in mesh smoothing and generalized swapping. With the use of these operators, P2 mesh generation starting from a P1 mesh is more robust and P2 connectivity-change moving mesh methods for large displacements are now possible.
https://hal.inria.fr/hal-01962132 Contributor : Rémi FeuilletConnect in order to contact the contributor Submitted on : Thursday, December 20, 2018 - 2:06:25 PM Last modification on : Friday, February 4, 2022 - 3:33:43 AM Long-term archiving on: : Friday, March 22, 2019 - 12:43:59 PM
