Rigorous modeling of light absorption in nanostructured materials using a parallel high order finite element time-domain technique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
The numerical modeling of light interaction with nanostructured materials is at the heart of many computational photonics studies. A typical example of interest to the present work is the simulation of light trapping in complex photovoltaic devices. This can be a challenging task when the underlying material layers are textured in a very general way. Very often, such studies rely on the Finite Difference Time-Domain (FDTD) method. The FDTD method is a widely used approach for solving the system of time-domain Maxwell equations in the presence of heterogenous media and complex three-dimensional structures. In the classical formulation of the this method, the whole computational domain is discretized using a uniform structured (Cartesian) grid. In this work, we consider an alternative approach by adapting and exploiting a particular finite element method, which is able to deal with topography conforming geometrical models based on non-uniform discretization meshes. The underlying modeling method is known as the Discontinuous Galerkin Time-Domain (DGTD) method. It is a discontinuous finite element type that relies on a high order interpolation of the electromagnetic field components within each cell of an unstructured tetrahedral mesh.
Fichier non déposé
hal-01962363 , version 1 (20-12-2018)
  • HAL Id : hal-01962363 , version 1
Stéphane Lanteri, Alexis Gobé, Urs Aeberhard, Karsten Bittkau. Rigorous modeling of light absorption in nanostructured materials using a parallel high order finite element time-domain technique. Computational Optics 2018, May 2018, Francfort, Germany. ⟨hal-01962363⟩
93 Consultations
0 Téléchargements
