Traveling waves for some nonlocal 1D Gross-Pitaevskii equations with nonzero conditions at infinity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Continuous Dynamical Systems - Series A Année : 2020
We consider a nonlocal family of Gross-Pitaevskii equations with nonzero conditions at infinity in dimension one. We provide conditions on the nonlocal interaction such that there is a branch of traveling waves solutions with nonvanishing conditions at infinity. Moreover, we show that the branch is orbitally stable. In this manner, this result generalizes known properties for the contact interaction given by a Dirac delta function. Our proof relies on the minimization of the energy at fixed momentum. As a by-product of our analysis, we provide a simple condition to ensure that the solution to the Cauchy problem is global in time.
GPN-final.pdf (1 Mo) Télécharger le fichier
hal-01962779 , version 1 (20-12-2018)
hal-01962779 , version 2 (16-07-2019)
hal-01962779 , version 3 (23-09-2019)
André de Laire, Pierre Mennuni. Traveling waves for some nonlocal 1D Gross-Pitaevskii equations with nonzero conditions at infinity. Discrete and Continuous Dynamical Systems - Series A, 2020, 40 (1), pp.635-682. ⟨10.3934/dcds.2020026⟩. ⟨hal-01962779v3⟩
260 Consultations
243 Téléchargements
