On the Marshall–Olkin Copula Model for Network Reliability Under Dependent Failures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Reliability Année : 2019
The Marshall-Olkin (MO) copula model has emerged as the standard tool for capturing dependence between components in failure analysis in reliability. In this model, shocks arise at exponential random times, that affect one or several components inducing a natural correlation in the failure process. However, because the number of parameter of the model grows exponentially with the number of components, MO suffers of the "curse of di-mensionality." MO models are usually intended to be applied to design a network before its construction; therefore, it is natural to assume that only partial information about failure behavior can be gathered, mostly from similar existing networks. To construct such an MO model, we propose an optimization approach to define the shock's parameters in the MO copula, in order to match marginal failures probabilities and correlations between these failures. To deal with the exponential number of parameters of this problem, we use a column-generation technique. We also discuss additional criteria that can be incorporated to obtain a suitable model. Our computational experiments show that the resulting MO model produces a close estimation of the network reliability, especially when the correlation between component failures is significant.
J57.pdf (2.9 Mo) Télécharger le fichier
hal-01962918 , version 1 (21-12-2018)
Omar Matus, Javiera Barrera, Eduardo Moreno, Gerardo Rubino. On the Marshall–Olkin Copula Model for Network Reliability Under Dependent Failures. IEEE Transactions on Reliability, 2019, 68 (2), pp.451 - 461. ⟨10.1109/tr.2018.2865707⟩. ⟨hal-01962918⟩
91 Consultations
304 Téléchargements
