Adaptive dynamics of hematopoietic stem cells and their supporting stroma: A model and mathematical analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Biosciences and Engineering Année : 2019
We propose a mathematical model to describe the evolution of hematopoietic stem cells (HSCs) and stromal cells in considering the bi-directional interaction between them. Cancerous cells are also taken into account in our model. HSCs are structured by a continuous phenotype characterising the population heterogeneity in a way relevant to the question at stake while stromal cells are structured by another continuous phenotype representing their capacity of support to HSCs. We then analyse the model in the framework of adaptive dynamics. More precisely, we study single Dirac mass steady states, their linear stability and we investigate the role of parameters in the model on the nature of the evolutionary stationary distributions (ESDs) such as monomorphism, dimorphism and the uniqueness properties. We also study the dominant phenotypes by an asymptotic approach and we obtain the equation for dominant phenotypes. Numerical simulations are employed to illustrate our analytical results. In particular, we represent the case of the invasion of malignant cells as well as the case of coexistence of cancerous cells and healthy HSCs.
HTE_V2.pdf (1.04 Mo) Télécharger le fichier
hal-01963820 , version 2 (29-04-2019)
Thanh Nam Nguyen, Jean Clairambault, Thierry Jaffredo, Benoît Perthame, Delphine Salort. Adaptive dynamics of hematopoietic stem cells and their supporting stroma: A model and mathematical analysis. Mathematical Biosciences and Engineering, 2019, 16 (05), pp.4818-4845. ⟨10.3934/mbe.2019243⟩. ⟨hal-01963820⟩
606 Consultations
364 Téléchargements
