Dependence properties and Bayesian inference for asymmetric multivariate copulas - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
We study a broad class of asymmetric copulas introduced by Liebscher (2008) as a combination of multiple-usually symmetric-copulas. The main thrust of the paper is to provide new theoretical properties including exact tail dependence expressions and stability properties. A subclass of Liebscher copulas obtained by combining Fréchet copulas is studied in more details. We establish further dependence properties for copulas of this class and show that they are characterized by an arbitrary number of singular components. Furthermore, we introduce a novel iterative representation for general Liebscher copulas which de facto insures uniform margins, thus relaxing a constraint of Liebscher's original construction. Besides, we show that this iterative construction proves useful for inference by developing an Approximate Bayesian computation sampling scheme. This inferential procedure is demonstrated on simulated data.
asymmetric_multivariate_copulas.pdf (2.25 Mo) Télécharger le fichier
hal-01963975 , version 1 (21-12-2018)
hal-01963975 , version 2 (28-06-2019)
  • HAL Id : hal-01963975 , version 1
Julyan Arbel, Marta Crispino, Stéphane Girard. Dependence properties and Bayesian inference for asymmetric multivariate copulas. 2018. ⟨hal-01963975v1⟩
268 Consultations
155 Téléchargements
