Quasi-optimal nonconforming approximation of elliptic PDES with contrasted coefficients and minimal regularity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
In this paper we investigate the approximation of a diffusion model problem with contrasted diffusivity and the error analysis of various nonconforming approximation methods. The essential difficulty is that the Sobolev smoothness index of the exact solution may be just barely larger than one. The lack of smoothness is handled by giving a weak meaning to the normal derivative of the exact solution at the mesh faces. The error estimates are robust with respect to the diffusivity contrast. We briefly show how the analysis can be extended to the Maxwell's equations.
contrasted_diffusivity.pdf (440.08 Ko) Télécharger le fichier
hal-01964299 , version 1 (21-12-2018)
hal-01964299 , version 2 (03-05-2021)
hal-01964299 , version 3 (24-11-2021)
  • HAL Id : hal-01964299 , version 1
Alexandre Ern, Jean-Luc Guermond. Quasi-optimal nonconforming approximation of elliptic PDES with contrasted coefficients and minimal regularity. 2018. ⟨hal-01964299v1⟩
282 Consultations
199 Téléchargements
